Posted: Wed Sep 14, 2011 10:46 am Post subject: What making system do you use? |
This is a general question for any makers out there. If you had two minutes to describe your making "system " , what would you say? What do you believe works best and is the most important ? Names of book writers will not be a lot of use here unless you say what the book writer believes . Anything like dissolving in acid or boiling in camel dung would be classed as a system. (Damn it , I just gave away my best secrets ). Varnish can be accepted if you must point that way. You don`t have to be original if you don`t want to.
Maybe a better question would be --What systems are there? Then nobody has to be nervous . Partly this is to see if it`s better not to tell. |
Posted: Sun Sep 18, 2011 9:54 pm Post subject: System |
Trial and error. _________________ Dave in the Blue Ridge
Posted: Mon Sep 19, 2011 8:31 am Post subject: System |
I think you could consider
Inside Mould - traditional Italian method
OUtside Mould - French method
Built on the Back
I also know a maker that does the arching inside first, while most of us do the outside arch first then graduate. Not sure if that would be a "system" or just a method. _________________ Dave in the Blue Ridge
Posted: Mon Sep 19, 2011 2:29 pm Post subject: |
| Dave that would be your physical method but is there a part that you believe makes a certain kind of sound or tone? That sort of method. There are lots of --That won`t work --type of reactions but not much to fill the gap left. Is there a method you have heard of that gives consistent reliable results or does it boil down to good set-up methods? |
Posted: Mon Sep 19, 2011 2:42 pm Post subject: System |
Thanks for clarifying... _________________ Dave in the Blue Ridge
okawbow Member
Posted: Wed Sep 21, 2011 8:36 am Post subject: tone |
Besides using willow for blocks and lining, I coat the outside and inside of the body with propolis resin disolved in acetone. When brushing on the solution; it typically penetrates to the back side of the wood.
I've been told by several good players that my instuments have a "mature" tone, like older instruments. It also makes them smell wonderful!  |
Posted: Wed Sep 21, 2011 11:57 am Post subject: |
| An inside out man. Did it feel risky when you did that first? Maybe we should all do at least one each like that . How careful are makers about the internal volume? If you keep strictly to the rib depth measurements of a good old violin and then use harder or softer wood the thickness difference will leave different air volumes . I knew there was a question nagging at the back of my head. It`s just beginning to surface now. Yes It`s starting to link up with conflicting information given in books and articles. One source says Stradivarius hardly ever changed the air volume. Is that really true? Is there a record kept when repairers open an instrument. Fine dry sand might give a good usable figure. Then plate tuning comments vary. One says the back is always one tone higher than the belly. Another says both plates are the same. ( Both stated for Stradivarius ) Also reports that Guarnerius made some with the back a semitone lower than the belly. That`s what I read. I`ve never held one. The Strad magazine gives thickness of plates but rarely mentions tap tones in the same article. But which tap tones matter? Where do you tap and where do you hold? Is a free plate anything like a plate attached to the rest of a violin? Who should you believe when it`s written down.(To every maker --a detractor. ) Maybe that`s the fun of it all. |
okawbow Member
Posted: Wed Sep 21, 2011 12:42 pm Post subject: |
I don't even worry about tap tones anymore. I graduate the plates based on how they "feel" when I flex them. I set the rib height based on the difference of the plate thickness and arching from "normal". So, I guess I try to keep the internal volume the same.
I was not too worried about using propolis, as it has been used for centuries in one way or another on instruments. |
Posted: Sun Sep 25, 2011 9:01 am Post subject: |
| When you say "any more" what changed your mind? What put you off tap tones? |
okawbow Member
Posted: Sun Sep 25, 2011 9:35 am Post subject: |
| amezcua wrote: | | When you say "any more" what changed your mind? What put you off tap tones? |
I made 2 identical violins, ( same wood, form, everything) and carefully matched the tap tones. One played and sounded great; the other was a dud. I had noticed when graduating, that the best sounding fiddle had "felt" different than the dud, when I reached the same tap tone. The plates felt lighter and more flexible in my hands. I believe it was a combination of wood density, minute differences in arching, and graduation thickness. And, even though it produced the same tap tones; it didn't produce the same quality sound when finished and played.
There are just too many other variables, such as the fitting of the bass bar, the position and size of the sound holes, ground, varnish, thickness of the linings, block size and shape, sound post size and position, neck set, and bridge quality and fitting; for tap tones to make any real difference in the final sound.
I was able to get the "dud" violin to play and sound at least "average", by working on some of those variables. However, I lean toward the idea that all else being equal; the air volume is the determining factor in the final sound. |
Janito Member
Posted: Sun Sep 25, 2011 7:14 pm Post subject: |
| okawbow wrote: |
This statement appears not to be supported by your comments on the variables you changed in the Dud or the other factors mentioned. |
Posted: Mon Sep 26, 2011 11:10 am Post subject: |
Yes, and the post was going so well, too.  _________________ You can only connect the dots that you have. |
okawbow Member
Posted: Mon Sep 26, 2011 4:54 pm Post subject: |
Actually it is supported in the "all things being equal" statement.
I have found that identical violins as far as everything in materials, construction and set-up, but having diferent air volume because of rib height; sound different.
All the other factors also affect sound, but usually can be modified somewhat. |
Posted: Mon Sep 26, 2011 6:47 pm Post subject: |
| Hmm. I've found that all violins made as identically as possible with the SAME air volume still sound different. Is it safe to assume that you have made a number of violins that all sound the same? |
okawbow Member
Posted: Mon Sep 26, 2011 9:07 pm Post subject: |
My last 4 or 5 have been made with an effort to match the rib height, arching, and graduation, etc. of my best sounding violin to date. They all have a "good" easy to play, and similar sound. Better than earlier fiddles that were made more at random. No, they don't sound exactly the same. I'm obviously not good enough to get all the variables, including the air volume the same. but, they all have a similar voice, that is closer to my best violin than to earlier attempts. I believe volume is very difficult to reproduce, but worth the effort.
I think the best violins must have the right air volume, as well as all the other things right. It's not easy to get it all correct unless you make a lot of fiddles. I make archery longbows for a living. I've made upwards of 2000 bows in my lifetime, and am still finding ways to get better and more consistant. I may be getting too old to improve much more, though. Stadavari made hundreds of violins, and not all of them sounded the same. Of course, some were ruined by others "improving" them, but I'm sure some sounded better than the rest. I'm also sure he improved as he made more and more fiddles. |
