bobharford Junior Member
Posted: Fri Aug 19, 2011 11:33 am Post subject: Restoring old violin |
Hi New here!
I found a violin in a wooden case at the local refuse tip. It is a bit battered and two of the tuning pegs are twigs.
I want to replace them and see if `i can get it going. The body work is worn but fine.
Can I do the pegs by filing and sanding them down ?any tips to do this.
Or should I take it back to the tip?
It has steiner stamped on the body and look s about over 50 years old.
I could put a picture on here
Thank you
Bob |
Posted: Fri Aug 19, 2011 2:30 pm Post subject: |
You really need a peg reamer and shaper to properly fit pegs. Take it to a luthier to have it looked at. There might be other significant things wrong with it that you're not aware of. _________________ Doug Wall
