siren71 Junior Member
Posted: Thu Oct 21, 2010 1:50 pm Post subject: 2 technique questions from a mid-level player |
Hi!
It's been a long time since I've had violin lessons, but I still play - and have developed some bad habits... Here are 2 problems I'd love some tips on:
1) I occasionally make the E string "squeek." (Not sure how else to describe the high-pitched harmonic-like sound). It mostly occurs when I sweep the bow across all 4 strings and end on the E string. I can't figure out what I'm doing that's causing this. Any ideas?
2) I habitually play in either 1st or 3rd position - but I'd like to go up a little higher. I'm not sure what approach to take... Is there a position I should practice in which is commonly used (ex., 5th position being common, but 6th being rare)? Or should I stop thinking about positions higher up on the fingerboard and mostly concentrate on notes and scales? Any advice on moving above 3rd position?
Many thanks!! |
Chad48309 Member
Posted: Thu Oct 21, 2010 4:02 pm Post subject: |
Make sure you're using a wound E, it helps. First and foremost, make sure you're precisely perpendicular to the string. It can be easy to slip onto a diagonal when you do a run like that. _________________ -C.S. |
AntonPolezhayev Member
Posted: Fri Oct 22, 2010 11:50 am Post subject: |
1- Everyone makes e whistle sometimes. Use 4th finger when crossing over when possible Better be safe than sorry. Obviously you should also have your violin and bow checked and adjusted by a high level professional repairman, and experiment with different strings and rosin, as well as experiment with bow pressure and timing when you cross to the e.
2- practice 1-finger 1-octave scales on one string. Take your favorite song and play it with one finger on one string instead of in one position with 4 fingers. Gently curve around the fingerboard, get to know it. Practice octaves etc. Use a Hrimaly scales book. _________________ http://www.youtube.com/watch?v=OLDeYZXUDDQ |
Posted: Sat Oct 23, 2010 1:11 pm Post subject: |
This is all great advice.
Thanks!
If anyone else wants to weigh in - especially on using higher positions, that would be great. I'd like to know a little more about which positions are most standard... |
Lemuel Site Admin
Posted: Sat Oct 23, 2010 11:06 pm Post subject: |
Yes, I get the whistling E from time to time, and it happens mainly when crossing over with the same bow stroke (a slur), whether up or down. What I have found very helpful is to accentuate the E with a little more, but very short pressure of the bow, much like you are accentuating the beginning of the first beat in each measure of music.
For positions, I found "Sevcik School of Technic for Violin, Op. 1, Part III, Exercises for the change of positions", to be most helpful. |
RuthBrons Junior Member
Joined: 19 Mar 2010 Posts: 6 Location: West Orange, NJ
Posted: Tue Oct 26, 2010 9:53 am Post subject: |
The squeaky E string can be blamed on so many things --
bad string, barometric pressure, errant flesh touching the string, etc.
Classic advice is to jar the stubborn string into vibration by deliberately skewing the angle of the bow and adding extra bow pressure when first entering the string.
But, what I found with my students who have a stubborn recurring squeak, especially when slurring into an E string on a down bow, is that the bow hand/arm remembered to lower into the E string, but forgot keep the bow totally parallel to the bridge. Thus the bow has wandered too far to the fingerboard and there is not enough pressure to get the string to sing properly.
Best Wishes, _________________ Ruth Brons
Inventor of Bow Hold Buddies[tm] Instant Bow Hold bow accessory for Beginners
www.things4strings.com |
Lemuel Site Admin
Lemuel Site Admin
Posted: Sat Oct 30, 2010 9:54 pm Post subject: |
I spent some time experimenting and was able to duplicate or produce the whistling E sound at will. I was using a Pirastro steel E on my violin.
After changing the E string to the "Pirastro #1 Non-Whistling E string", I am unable to duplicate it. |
