Stradigenious Junior Member
Posted: Sat Sep 04, 2010 4:13 am Post subject: Violin varnish |
Hy all
I've got a question regarding the production of violin varnish. I have an old italian violin varnish recipe and the recipe talks about cooking of vanetian turpentine with quick lime. I have found out that it should be cooked to dry it, but i don't understand why it should be dry. Does anybody have an idea?
Thanks a lot
regards
Stradigenious _________________ www.spanishguitars.ch |
rs Member
Posted: Sat Sep 11, 2010 10:39 pm Post subject: |
Because water can dissolve in the solution being prepared. The dissolved water tends to make the varnish made from this solution cloudy. Drying the components drives the water out. Dissolving the DRY components anew pretty much eliminates this dilemma. _________________ Randall Shenefelt |
Janito Member
Posted: Sun Sep 12, 2010 9:41 am Post subject: |
| Lime has been used to neutralize highly acidic resins, not for the dehydration properties. One could simply evaporate water for that. |
Violin Repair Guy Junior Member
Posted: Tue Sep 14, 2010 2:03 pm Post subject: Violin Varnish |
I agree with rs & Janitos, they have some good information, Thank you.
I would also like to add that sometimes when trying to mix your own finishes such as varnish, it helps to use low heat so the components blend easier. Components that are oil-based respond well to heat when mixing, (Not open flame but heat, lol) _________________ Eric Luthier
The Violin Repair Guy |
