Oded Kishony Member
Posted: Wed Jul 16, 2008 11:16 pm Post subject: |
| Quote: | | 'Ive been using the same recipe for 20 years now, |
Since you brought it up David, care to share with us?
Manfio,
| Quote: | | Why this Stradivarian atavism? |
I've never played an instrument as good as the best Strad. It stands heads and shoulders above the rest.
Oded |
David Tseng Junior Member
Joined: 14 Jul 2008 Posts: 7 Location: Lake of the Woods, ON
Posted: Fri Jul 18, 2008 9:37 pm Post subject: |
The reason is like this: one could copy the shape and thickness as close as possible like Vuillaume did but still could not copy the sound. The varnish of many old violins had worn out but still sounded great. We therefore came to the conclusion that their wood is different.
Oded, I have not cracked i segreti di Stradivari. We all have to do our homework. |
Oded Kishony Member
Posted: Sat Jul 19, 2008 7:28 am Post subject: |
| Quote: | | The reason is like this: one could copy the shape and thickness as close as possible like Vuillaume did but still could not copy the sound. The varnish of many old violins had worn out but still sounded great. We therefore came to the conclusion that their wood is different. |
Hi David,
There are several other possibilites including the effect of the sealer and or sizing. Or construction method not yet understood. Sacconi for instance suggested that the Cremonese may have voiced their instruments in the white from the outside.
Oded |
CT Dolan Member
Posted: Wed Jul 23, 2008 1:45 pm Post subject: |
I asked the questions below in the forum on Stradivari's duds and thought Id ask them here as well, in case some of you are not navigating the other forum. So, here goes:
Of the two most highly-regarded makers, Stradivari and del Gesu, whom would you rather spend a week working alongside, and why? What if I threw Andrea Amati into the mix, where would he rate? I know these are rather silly questions, but humor me. |
CT Dolan Member
Posted: Wed Jul 23, 2008 1:55 pm Post subject: |
Also, I have a couple other questions which may seem off topic, but in reality are not.
In the Biddulph publication on the work of del Gesu (whose violins are beyond description on so many levels, if you ask me), in particular in the section that deals with the Cannone (a gracious gift, but I'll say no more), the author (Roger Hargrave?) mentions the lack of a ground coat on the wood, namely "...and no separate ground coat is easily distinguishable; areas of intact, slightly opaque orange-brown varnish give way suddenly to dirty, raw wood." What can we make of this? If this is true, why is the ground coat given such great significance?
Second, in the Sacconi publication on the work of Stradivari, he mentions a treating of the internal surface of the wood. What is the current thought with regard to this observation?
To many here, the questions I have asked above may seem pedestrian, but I am curious with regard to the above, so please answer if you are able. |
CT Dolan Member
Posted: Wed Jul 23, 2008 2:39 pm Post subject: |
| Regarding the above, let's make our experience in the shop of the Cremonese master of your choice a full apprenticeship so we can actually learn something, and get to know the maker in person. Again, I realize that it is a bit of a silly question, but the reasons for choices have the potential to make it interesting. |
Posted: Wed Jul 23, 2008 6:10 pm Post subject: |
| CT Dolan wrote: | I asked the questions below in the forum on Stradivari's duds and thought Id ask them here as well, in case some of you are not navigating the other forum. So, here goes:
This was a question in one shop where I worked. I chose Nicolo Amati, and no one understood, because he's not a very highly respected maker. My response was "look at what his students did, and look at the students of del Gesu and Stradivari and what they accomplished [that is, nothing]." If I wanted to be an apprentice, I'd choose the best teacher, not the best maker. in that vein, Andrea Amati would be my second choice. |
CT Dolan Member
Posted: Wed Jul 23, 2008 8:04 pm Post subject: |
| Very good response, very good indeed. We can guess at the reasons why Stradivari and del Gesu left no accomplished apprentices in their wake, and no doubt some of this may be due to the personality of the maker (which means that even though immersed in their environment, we might not learn much). Actually, this is the reason I threw Andrea Amati into the mix, but I had never given thought to Nicolo. Once again, my lack of experience and knowledge shines through! |
