JWH Member
Posted: Fri Jul 06, 2007 12:38 pm Post subject: UV Drying |
I haven't made a UV box yet but might ask the simple questions about the best bulbs to use.
Does polymerization most readily react to UVA long length, UVB medium length or UVC short length radiation?
Would a full spectrum bulb with UV enhancement be sufficient? I don't much care about building heat up with infrared.
From what I've read UVC is germicidal, dangerous and not recommended. Apparently 99% of atmospheric UV is UVA since ozone is most effective in filtering out shorter wavelengths.
I thought someone here might know some of the better bulbs to use and sufficient wattage.
I've heard folks mention finding throw-away tanning bulbs. Apparently, bulbs lose UV generation after time even though they continue to glow and the effective radiation distance from the bulb surface declines. |
mikemolnar Member
Posted: Fri Jul 06, 2007 9:50 pm Post subject: |
I use germicidal T10 lamps from 1000Bulbs.com. You want to fit the most lamps possible (maximum wattage) in your box. The inside of the box should be lined with aluminum foil. Mine also has a muffin fan that pulls the air in through a filter at the bottom of the box. The air exits at the top. The door also has a small UV absorbing plastic window.
It also has a thermometer. The inside is a comfortable 82F.
Final note: make the box big enough to hold your largest projects! |
JWH Member
Posted: Fri Jul 06, 2007 11:59 pm Post subject: |
| Thanks, Mike..............chunk of change aren't they? |
Posted: Sat Sep 08, 2007 11:21 pm Post subject: UV Bulbs |
I'm new on this forum, but post on some other forums. Although I haven't built a cabinet myself, yet, I have looked into it. It turns out that fluorescent bulbs used by people who raise reptiles are high in both UVA and UVB. Do a search under "reptile light" and you should turn up some info. _________________ Doug Wall
