how to ream only one peg hole
PostPosted: Mon Feb 27, 2012 8:54 pm    Post subject: how to ream only one peg hole Reply with quote
If only one of the two holes for a peg in a pegbox needs to be repaired it needs to be reamed oversize and cleaned to recieve the plug or spiral bushing. How can you ream the hole in one side of a peg box without also doing the otherside... just trying to save as much of the original as possible...
bata
PostPosted: Tue Feb 28, 2012 10:51 am    Post subject: Reply with quote
Hi Mat,
Depending on how big the peg hole is, could you use a cello reamer?
If the hole is too small, you might have to open it up a bit with a drill to start the larger reamer.
Tony
PostPosted: Tue Feb 28, 2012 11:06 am    Post subject: Reply with quote
Hi Tony... Duh! Why did I not think of the obvious! ... Must be nice to have a young brain! For the job at hand that will work perfect.
Thanks... Mat
PostPosted: Tue Feb 28, 2012 4:14 pm    Post subject: Reply with quote
Personally I would not recommend reaming only one side. I think you will find it VERY difficult to ream the hole without a little wobble, then the plug will not fit perfectly. The second hole helps keep things in line. But I suspect you will find out for yourself how well it works.
DonLeister
PostPosted: Thu Mar 01, 2012 12:03 am    Post subject: Reply with quote
Ditto, it will wobble. Could you add a temporary block onto the pegbox wall to give the reamer more support?
PostPosted: Thu Mar 01, 2012 8:32 pm    Post subject: Reply with quote
Actually, I did the opposite... I created a firm saddle to hold the peg box and then made a saddle to fit the reamer just under the handle where the shaft is round and smooth...That held it all secure and kept it wobble free... worked well
Thanks for the heads up... I would have otherwise attempted it freehand... Cheers, Mat
