Purfling Question
YewPineyFiddler
PostPosted: Thu Aug 06, 2009 5:21 pm    Post subject: Purfling Question Reply with quote
Hello Everyone,
I am new to the forum. I'm making my first violin and my next step is the purfling. I have a Ibex purfling marker (like the one Mr. Luscombe sells on his website) it has 2 single bevel blades with the combined thickness of 2.18 mm, which as you know is to thick for violin purfling.
So, I'm not sure what to do next? Should I reduce the thickness of the blades? If so how? How close in thickness should the blades be in relation to the purfling? I've seen it listed at 1.2 to 1.3mm
I've read that some makers round the blades of the marker. Dose that help?
Sorry for all the questions it's not easy on your own,
Daniel
PostPosted: Thu Aug 06, 2009 6:43 pm    Post subject: Reply with quote
For a start, turn the blades over so the flat sides are together. Then you can shim between them to get the width you want. I have mine sharpened in a rounded end so I can go in either direction, but I had to reshape the guide finger so it was opposite the centers of the blades. I'm not sure that was really necessary.
With two blades, this tool is only for marking, and you would deepen each cut with a knife after marking them, which is probably an easier way to make things more precise. If you want to try cutting all the way down, use only one blade, and you'll have to reset it for either side of the purfling, of course..
Last edited by Michael Darnton on Fri Aug 07, 2009 10:45 am; edited 1 time in total
violinarius
PostPosted: Fri Aug 07, 2009 9:17 am    Post subject: Re: Purfling Question Reply with quote
YewPineyFiddler wrote:
Hello Everyone,
Daniel
Michael Darnton hit the nail on the head, perhaps he has been making baroque necks lately, and I would just add about the thickness ...
Most people copying Stradivari instruments choose a finished channel width of 1.2 mm.
This width can varies somewhat, but 1.2 should do.
If you are buying your purfling, then you have to go with what you get if it is under 1.2 mm, and you can judiciously scrap down both sides, evenly, if it is thicker than 1.2 mm, to fit your instrument.
The white section is normally around 0.6 mm and the blacks 0.3mm each.
The best thing you can do is work all this out on a few pieces of scrap, that way you will make your mistakes where it does not matter.
PostPosted: Tue Aug 11, 2009 7:13 pm    Post subject: purfling Reply with quote
I've found that scraping (slightly beveling) the bottom corners that go into the channel first, helps. Also, rather than thinning the purfling, I've heard others talk about compressing it a bit with a wooden roller (rolling pin?), and it will swell with the glue to fill the channel. I've not tried this, but it makes some sense.
I use my Ibex purfling tool only for marking the long sections, not for cutting the channel itself. Then I finish cutting the channel with exacto knife with a new blade. I also take a sharp pencil and draw in the curves into the corners rather than try to use the marking tool because its very difficult to make the tight turns. Next, I draw my final lines into the corners with the tip of my exacto knife, and rub the pencil lead into the knife marks to preserve them as I work, and erase the remainder of the pencil marks. These are light enough marks that they'll be long gone after finishing my edges..
YewPineyFiddler
PostPosted: Mon Aug 17, 2009 9:23 pm    Post subject: Purfling Question Reply with quote
Thank you all, your input has been most helpful. I have a scrap back I'm going to practice on before I work on my good violin. I know it will be a lot of extra work but I think I need it.
I'm sure I'll have some more questions soon,
Thanks again,
Daniel
