violin size and sound
actonern
PostPosted: Fri Jul 04, 2008 1:30 pm    Post subject: violin size and sound Reply with quote
The Hill book on Stradivari has an appendix setting out the measurements of a number violins throughout various periods of the makers life.
The widths especially varied considerably, often reaching 8 1/2 inch, or about 109.5 mm in the lower bouts.
Lots of Guarneri violins are a lot narrower than that, as much as 5 or more mm less.
I'm interested in opinions on the effect of size on sound (assuming all other variables are constant, if that's possible.)
I read in one of Michael Darnton's past posts that a too large instrument will tend toward hollowness and lack of focus. But what is too large? A 1734 Stradivari in the Hill book has a length of 14 1/8 inch, sides of 1 1/4, top bout 6 3/4, lower bout of 8 1/4.
Thats a pretty big violin compared against lots of other makers, and yet is highly praised for it's sound.
PostPosted: Fri Jul 04, 2008 2:35 pm    Post subject: Reply with quote
Yes, that's a big violin, and I'm sure it sounds great. If only I could pull off everything he does, though. :-) When I spoke about big violins, I meant those made by mortals.
actonern
PostPosted: Fri Jul 04, 2008 2:41 pm    Post subject: Reply with quote
My son's violin teacher has a quite small Andrea Guarneri... could almost be a 7/8 size, and the complex harmonics and focused sound makes one wonder why you'd ever want to go bigger.
So is size relatively unimportant?
Andres Sender
PostPosted: Fri Jul 04, 2008 4:08 pm    Post subject: Reply with quote
Unimportant to whom and for what? Mortals or non-mortals; tone, tonal range, or projection? Wink
Not to mention response, i.e. 'ease of production', as the Hills call it.
PostPosted: Sat Jul 05, 2008 8:06 am    Post subject: Reply with quote
I would say size is very important.
If you can control all of the variables you might win; Stradivari's big violins are some of his best. However, Vuillaume and his contemporaries, and later Germans, decided they would make big violins for that reason, and things didn't turn out as well for them. The general problem is that larger instruments *tend* towards being more diffuse sounding, and smaller ones *tend* to have more core and intensity. For someone who can control the tendency towards diffusion, a large model has a lot to recommend it.
actonern
PostPosted: Sat Jul 05, 2008 7:51 pm    Post subject: Reply with quote
So anyway... I was doing a setup on a new instrument today... got to fitting the bridge late this afternoon, and discovered that a Molson Export beer cap weighs about exactly 1.9 grams... just about the ideal bridge weight!!!
Ahem...
MANFIO
PostPosted: Sun Jul 06, 2008 6:22 pm    Post subject: Reply with quote
One of the best violin sounds I ever heard was produced by Leonidas Kavacos on a long Strad.
www.manfio.com
CT Dolan
PostPosted: Mon Jul 07, 2008 9:22 pm    Post subject: Reply with quote
The Stradivari violins that Oistrakh played, both the Marsick and the earlier one he owned (I forget the name of his earlier one, but both were made prior to Stradivari's "Golden Period"), are simply marvelous. One would be hard-pressed to find a better sound, and I do not believe either of these instruments would classify as large in size, although I may be wrong.
MANFIO
PostPosted: Tue Jul 08, 2008 7:35 am    Post subject: Reply with quote
Oistrack is my favourit player...
In the DVD "The Art of The Violin" Perlman mentions that Oistrack's violin was not a particularly good Strad.
www.manfio.com
CT Dolan
PostPosted: Tue Jul 08, 2008 12:19 pm    Post subject: Reply with quote
Which means that Oistrakh must have been an even better violinist than I had previously thought! Surprised
Perlman's 'ex-Soil' Stradivari certainly must rank among the better ones out there. I love the close-up of the back of the ex-Soil in Sacconi's book (the close-up of the c-bout). The form is gorgeous and the "texture" of the flame stunning!
