Experimentation
Goto page 1, 2, 3, 4  Next
Geemac
PostPosted: Thu Jun 11, 2009 12:49 pm    Post subject: Experimentation Reply with quote
This note is for those here who like to try ideas instead of sticking hard and fast to traditional violin making. Over past few years I have done some reasonable snooping and thinking about the old masters. In that research I have thought through to some conclusions that are subject to change as required by the discovery of more information. I invite the more talented makers among us to try what I have discovered at least once and report back to the board. Here is what I have found.
* Makers were poor.
* They made their own materials
Methods to try
* Boiled wood is easier to carve. Before gluing and carving, boil the wood, especially the spruce, in water with salt, epsom salts(Magnesium sulfate) and borax. After drying you will notice that your top spruce boards will 'ring' when tapped. How much to add? Boil up some scrap spruce and determine what you like.
* Use orange shellac to achieve the color you want.
* Use pummace and then rotten stone to smooth the shellac between coats.
* Make your own varnish. Luscombe Violins Inc. has a good selection of materials. Be sure to add burnt alum to the mix. It adds potasium to the finish. Here is a link to explain what it is: http://en.wikipedia.org/wiki/Potassium_alum
* This method adds volcanic earth particles, salt(sodium), borax, potasium and magnesium to the wood. I believe that at this point we have added the 'found' ingredients that are present in my friend Tony's violins.
* The method presented here will help to make the wood crisp and very dry. Anyone who has handled a speaker must have noticed that it is quite crisp and dry too, so you should get a better responsivenes and sweeter sound from your violins. I did.
I look foreward to reading about your results in this thread.
If you are a traditionalist, please take the time to try this method at least once before you pass judgement upon it. After all, this may be the traditional way to make a violin.
Cemonaly yours
Geemac
GeeMac
MANFIO
PostPosted: Tue Jun 16, 2009 12:49 pm    Post subject: Reply with quote
Hi! Our craft is a traditional one. Before experimenting with wood treatment, in general, we makers, have to produce an instrument with a good outline, good archings, graduation, scroll, varnish, set up, good sound and playability, etc.
In general, while we devolp these things we develop our own ideas about making and sound. In my case, I test small things, one small thing on each instrument. If it works, I keep it, if it does not work, I abandon it.
The wood treatment is a highly controversial issue. Count Cozio di Salabue, writing in 1790 "circa" about violin making (see his "Carttegio"), advises to get wood in Venice in the Arsenal, but to get it prior that it's put on the sea water. He also criticizes the sound produced by German maker because they use "treated spruce" in their violins.
What differences in sound have you noticed in your instruments after using this method?
www.manfio.com
Geemac
PostPosted: Tue Jun 16, 2009 1:07 pm    Post subject: Reply with quote
The difference I have noticed is a more pure overall sound to the instrument. Keep in mind that I am an amateur and I am retired, so I have a lot of time and no customers Smile) For me the investigation of the methods and materials of the old masters is enjoyable. I have posted what I have found, deduced and tried so the others on the violin forum may give it a try when they have some spare time. Perhaps you'll have some free time between customers to try it too.
I thank you for mentioning Count Cozio di Salabue. I shall look into his work. It was established in his time that salt improves the sound of any violin. As we know, salt removes moisture from anything therefore it would remove moisture from the spruce top making the top more crisp. A crisp top should act as a better resonator than a wet top. It would be easy, not time consuming and inexpensive to pour a generous amount of salt and or epsom salts onto a newly carved top and let is dry for a day or two and then clean the top and assemble the instrument.
Above all. Keep having fun.
GeeMac
MANFIO
PostPosted: Tue Jun 16, 2009 2:04 pm    Post subject: Reply with quote
Hi! Cozio reccomended to by the wood prior to its submersion in the sea water, that is, that is, he advised against the use of salty wood.
www.manfio.com
byacey
PostPosted: Sat Jun 20, 2009 12:54 pm    Post subject: Reply with quote
Hi Luis, I question if Cozio really knew that much about the actual practices of the violin makers of that time. Perhaps he was fed misleading information by many of the makers wanting to preserve their proprietary methods. This happens even today in various industries.
By the time Cozio was doing his research, methods and materials were already changing and this is probably why he didn't get any kind of accurate documentation on the varnish of that era, as an example. Even today few makers will offer a straight answer regarding their ground and varnish; you're the exception to the rule and I commend you for your openess and honesty.
If you believe what Nagyvary and his disciples advocate, the Cremonese used nothing but treated wood!
Bill
MANFIO
PostPosted: Mon Jun 22, 2009 8:06 pm    Post subject: Reply with quote
Thanks for your kind and generous words!
You are right, Count Cozio di Salabue had no direct contact with makers of the Golden Period. They were all dead in Cozio's time.
But he was a very cultured man (the equivalent today, given our education level, would be like having degrees on Oxford, Yale, Harvard and Sorbone) and had a huge collection of stringed instruments, (dozens of them, Strads, Guarneris, Amatis, etc). He also kept contact with virtually every important person connected to our craft that lived in his time, including Giovanni Marchi and Antonio Stradivari's heirs. He owned Stradivari's tools, molds, drawings etc. His writings about violin making are concise and objective, and you may find them usefull till today. He was very close to the Mantegazza brothers.
More important: he had a long relationship with Giovanni Baptista Guadagnini. Ok, Guadagnini is not a "Golden Period" maker, but he is the closest maker to them. As a matter of fact, the estimated value for soloist violins is about the following (this is not a fixed table price, of course):
1. Guarneri-Del Gesu the most valuable to $5 million
2. Stradivari-Antonio the most valuable to $5 million
3. Bergonzi-Carlo the most valuable to $1.2 million
4, Giovanni Baptista Guadagnini-the most valuable to
valuable to $900k.
That is, Guadagnini's violins are among the more expensive concert violins today and I think every living maker would love chatting with Giobatta Guadagnini for some many many hours, as Cozio did. Yes, we can't be sure that he was saying everything he knew. But he exposed his ideas freely on his letters to Marchi and many other persons. He was, after all, "un Conte, un Nobile".
www.manfio.com
PostPosted: Wed Jun 24, 2009 11:48 pm    Post subject: Reply with quote
Geemac... I would be concerned about the residue of salt in the wood... you are right that salt removes moisture from anything and if there is a residue of salt in the wood it will remove moisture from the air... and promptly create a damp top... especially in humid conditions like today in Southern Ontario where we hit 34 Deg C and I am guessing 70-80% humidity.
Cheers... Mat
Geemac
PostPosted: Thu Jun 25, 2009 8:27 am    Post subject: Reply with quote
I have had no acquired moisture trouble with the violins I have made this way. If you have any doubts, you may wish to use a poorer quality scrap wood and make a test violin to see if you like this method. Otherwise, just carry on having fun.
GeeMac
violinarius
PostPosted: Thu Jun 25, 2009 11:15 am    Post subject: Reply with quote
If the salt is in the wood it will remove the moisture from the wood and air and attach the moisture to itself. This will not reduce the weight of the wooden object, but it will in fact increase it since you now have added the weight of salt.
If you just place the top in salt, then as soon as it is removed from the salt, it will begin to take up moisture again. Only a short term effect here.
violinarius
PostPosted: Thu Jun 25, 2009 11:18 am    Post subject: Reply with quote
valuable to $900k.
Interesting point! Thanks
violinarius
PostPosted: Thu Jun 25, 2009 11:49 am    Post subject: Reply with quote
Bill
The answer is easy, how many makers since Count Cozio do you think have tried various wood/salt treatments, as well as other treatments?
How many have attained the level of the Masters from Cremona?
The real mis-information is that the Count was fed a bunch of lies.
Dr. Nagyvary has also found wood that was not treated. Somehow this gets lost in all the hype.
If Stradivari had a secret, would he use it all the time?
Are there any two instruments from Stradivari that are the same?
There is a whole list of theories about Stradivari, and ALL over the centuries have been tried, and found to be lacking.
So if salt has been tried a gazillion times by a gazillion makers, and none have been successful, I have to think that Count Cozio was given the right information about salt.
What conclusion does that leave one with?
Either people have not tried the right theory, or perhaps it is the skill of Stradivari that they have not been able to duplicate, or have over-looked.
If wood treatment was the key, then why would we not see the same price for all the other Cremonese makers?
Amati trained quite a few makers, and I think it is safe to 'assume' that they had access to the same wood pile, so if the secret is in the wood, then they should all be on the same level, but they are not.
If all these makers received the same training under Amati, then why are they all different? How do you teach talent?
Skill/talent can easily be dismissed because it isn't romantic enough to sell newspapers.
Lastly if wood is treated with salt, then this would be the easiest thing Scientifically to detect, and yet we do not have any papers from Dr. Nagyvary or others from the Scientific community to say that this was the case.
PostPosted: Thu Jun 25, 2009 2:12 pm    Post subject: Reply with quote
One thing that's always been interesting to me, though, is how the bad makers of the Amati camp could make as good of violins as they could. You seem to think that if they all had the "secret" they'd all be as good as Stradivari, automatically. I think they all shared something we call "secret" that put them ahead of everyone else, but they didn't all have the other skills required to make the best possible violin.
CT Dolan
PostPosted: Thu Jun 25, 2009 2:23 pm    Post subject: Reply with quote
I used to be lured by the notion of a secret of sorts (or a collection of secrets), but the more I have matured in my knowledge the more I have come to realize that these guys were just plain good. In addition to this they had very solid training, the likes of which is almost non-existent today, and lived in an ideal moment in history. You basically had a perfect storm, with the more gifted and skilled makers of the time able to use the situation to full advantage. Unfortunately, the prevailing cultural trends did allow much information to be left behind for later generations of makers, but we do still have the best part, the instruments.
By the way, the same situation is happening today (entire fields or professions nearing their historical peak). It is simply happening in other areas of interest. However, that said we do have some very good makers living among us, some of whom I've no doubt history will treat very kindly, as it should.
CT Dolan
PostPosted: Thu Jun 25, 2009 2:36 pm    Post subject: Reply with quote
"One thing that's always been interesting to me, though, is how the bad makers of the Amati camp could make as good of violins as they could. You seem to think that if they all had the "secret" they'd all be as good as Stradivari, automatically. I think they all shared something we call "secret" that put them ahead of everyone else, but they didn't all have the other skills required to make the best possible violin."
Well, you've certainly got a good point there. We don't know it all, and you can only reverse engineer to a certain extent, after which speculation takes precedence. At the heart of it all, though, is the maker and his or her skill, their ability to navigate a myriad of decisions, following the correct path as often as possible along the way. When it comes to this, the classical makers certainly seem to have had a better map, and were trained to read it well, but I still believe that some makers today have acquired the ability to pick their way along quite well also (not even taking into account the element of time, the process of natural selection and the supposed improvement in quality time seems to bring).
byacey
PostPosted: Fri Jun 26, 2009 11:17 am    Post subject: Reply with quote
I am not suggesting the use of salt, but it is very possible the Count was fed other misinformations to throw him off the scent. Would you as a maker really want an outsider spreading your proprietary methods that could affect your liveliehood? Remember these guys generally had a wife and kids to feed, so if some traveling nobleman showed up on your doorstep asking questions, how open would you be?
I am sure some of the information from his friend Guadagnini was accurate, but I suspect Guadagnini himself was already somewhat "out of the loop" as to what the Golden era Cremonese were doing.
The individual nature of wood makes it near impossible to build two instruments acoustically identical, except perhaps in a random longshot fluke of the odds, even with a special treatment being used. The treatment however could possibly make a well constructed mediocre violin into a fine violin.
All in all, I believe experimentation is a positive thing, but there's no progress in repeating the failed experiments of others, except maybe in self education of what not to do.
Regarding the salt, similar acoustical results could be realized by using a non-hygroscopic mineral instead of salt.
Bill
Page 1 of 4
