cutting the purfling channel
PostPosted: Wed Dec 27, 2017 6:19 pm    Post subject: Reply with quote
Michael, are you sure you didn't write that backwards?
PostPosted: Wed Dec 27, 2017 6:23 pm    Post subject: Reply with quote
You are right and I just corrected it! Thanks!
carl1961
PostPosted: Sun Jan 14, 2018 5:31 am    Post subject: Reply with quote
Greg M wrote:
Well I finally got my purfling channel cut on the back plate. I just went with the Dremel 3000 and bought the 1/16" carbide bit from Stew-Mac . I did it on 2 passes and lowered the depth by removing washers 1 mm. thick at a time. The purfling drops in with a light cleaning of the groove and tapping it in slightly. I am really pleased with the results. Now to finishing the rest of the plate . Have a good Christmas everybody.
Greg M thats what I use the Dremel 3000 and 1.3mm bit my second violin I made a jig to hold the dremel and a foot petal to lower the dremel I see in the video according to Michael I was going the wrong way
EDIT: I did a back plate today and video is correct, dremel is turning clockwise as it is mounted, and I am moving the plate instead of the router.
https://youtu.be/fQsPKnqSIuY
https://www.youtube.com/watch?v=JGug8C2rNyo
ollieken
PostPosted: Sun Jan 14, 2018 10:33 am    Post subject: purfuling Guide Reply with quote
Hello Carl Nice job I wonder if you would mind sharing a pic of the under side of the of the Dremel holder ( guides ) looks like a nice setup . Ken
carl1961
PostPosted: Mon Jan 15, 2018 1:28 am    Post subject: Re: purfuling Guide Reply with quote
OK first picture is the rig, what you don't see is to 1/2 collars or sleeves that after I set this in the holes I use the sleeve collars to lock it in up position
taped two holes in base for the long rods and one to mount the plastic extender
I used these toilet bolts to fine the hole distance
I used a piece of a old plastic part to extend the purflin tool base as it raises up.
I had to round a spot on the back of the plastic so that the long rod would be able to screw in the hole for it, it also served to keep the white plastic extender from turning and also sanded the plastic to match the base
I used whatever I had to make the pedal, the cable came off a riding lawnmower's blade engaging handle
two 3/4" plywood glued together for table remember to allow room behind jig for violin plate, I did not and had to mount it 2" of the wall.
I did a back violin plates today and the dremel goes clockwise so I did have to turn my violin plate clockwise to cut correct, dremel going anti clockwise
ollieken
PostPosted: Mon Jan 15, 2018 5:49 pm    Post subject: Purfling Reply with quote
Hello Carl Thank you for the pics Next project make one like it I have the Dremel Guide. I have never used it . Only one ? Where is the cable hooked to the guide on the Bottom with a small eye bolt . Ken
Rick M
PostPosted: Tue Jan 16, 2018 1:16 am    Post subject: Reply with quote
Carl, thanks for posting that. Really ingenious.
carl1961
PostPosted: Tue Jan 16, 2018 3:44 am    Post subject: Re: Purfling Reply with quote
Ok Ken, I went and took some pictures
Those brass screws or those two toilet mount screws
Those at the top of the shaft or bushing that go through that peice of plywood to help keep the jig from any wobble
carl1961
PostPosted: Tue Jan 16, 2018 4:02 am    Post subject: Reply with quote
Thanks Rick, even with this table I still make a wobble or two LOL, I guess time will allow me to get a steady hand. My biggest trouble is getting those miters where they look descent, we need a jig to help do those LOL
ollieken
PostPosted: Tue Jan 16, 2018 5:23 pm    Post subject: purfuling Reply with quote
Carl Thank You for the extra pic good job Ken
PostPosted: Tue Jan 16, 2018 6:40 pm    Post subject: Reply with quote
And it still won't work on a closed box. I'll stick with my Foredom.
carl1961
PostPosted: Wed Jan 17, 2018 6:53 am    Post subject: Reply with quote
Good point L P
I would likely work fine if it was modified and made adjustable to raised for the violin box. (I might think on that a while and try the closed box way, my rods or long enough I think to go the couple inches needed) I read it was better to do it on a closed box , I already ran into the issues where I needed to reshape the edge to have a nice uniform edge all around, but with the prufling already installed your stuck with what you have.
JPvln
PostPosted: Thu Jan 25, 2018 7:45 am    Post subject: Cutting purfling channel Reply with quote
Speaking of breaking spiral bits, I have read it recommended the depth of cut be no more than half the bit diameter. So that would take 3-4 passes to cut the channel. I've tried in one pass, but find it better to take 2 or more. I'd like hear how others do this.
PostPosted: Thu Jan 25, 2018 5:33 pm    Post subject: Reply with quote
I always do it in one pass and have never broken a spiral carbide bit. I broke several of the steel, straight flute bits before I switched. I did make a couple of single flute steel bits years ago that work but not as well as the carbide.
Rick M
PostPosted: Thu Jan 25, 2018 9:49 pm    Post subject: Reply with quote
I broke the lee valley (steel) bit within a couple of inches the first time I tried it.
With that one I couldn’t do more than 1/2 depth. I posted info earlier on some CNC type (so called by vendor) bits. I can do full depth in one pass with those. But SLOW moving.
Page 3 of 4
