bee-g Junior Member
Posted: Thu Sep 03, 2015 8:29 pm Post subject: New here and a question about the tail Button on a violin |
I am new to violins and recived a fairly cheap one. and Understand the tail button is not glued in but is meant to be removable but should it be so lose as to tilt and not lay flat when the violin is strung and tuned?
It does not seem to be slipping completely out but acts as if the hole is much larger than the peg of the tail button. |
DonLeister Moderator
Posted: Thu Sep 03, 2015 10:51 pm Post subject: |
| It sounds like it is poorly fit, it should be pretty snug. |
kjb Super Member
Posted: Fri Sep 04, 2015 7:19 am Post subject: |
| the button and the hole are tapered like the pegs in the head, to fix that you will need to take it to someone, to make the fit work . |
Posted: Fri Sep 04, 2015 8:01 am Post subject: Temporary fix |
On the other hand, for the time being, you could wrap a small strip of Kraft paper around the button, and stick it back in there. It doesn't take much paper, it is utterly reversible, and does no harm whatsoever. _________________ Chet Bishop
bee-g Junior Member
Posted: Fri Sep 04, 2015 10:09 pm Post subject: |
| Quote: | | On the other hand, for the time being, you could wrap a small strip of Kraft paper around the button, and stick it back in there. It doesn't take much paper, it is utterly reversible, and does no harm whatsoever |
will do that if it seems to be slipping more at least till I find funds to take it to a shop that does repairs. |
Franciscus Member
Posted: Sat Sep 05, 2015 4:14 am Post subject: |
| bee-g wrote: | | Quote: | | On the other hand, for the time being, you could wrap a small strip of Kraft paper around the button, and stick it back in there. It doesn't take much paper, it is utterly reversible, and does no harm whatsoever |
Do that right now, because the lose endpin could cause damage on the lower block and ribs, besides the problem with tuning. You can use masking tape, too. If you need just one layer of it, do that and leave as is, but if you put two layers or more, you should fit new endpin (if you do not need rebushing of endpin hole). |
Posted: Sat Sep 05, 2015 5:33 pm Post subject: |
| Chet and Franciscus are right. It isn't going to heal itself and a small problem can become big if you do nothing. |
