Stradsman Junior Member
Posted: Sat Apr 30, 2011 11:52 pm Post subject: Viola vs. Violin - the technique |
Just how different is the technique on the viola? I understand that it's tuned CGAD and that it's a bit bigger. I'd like to buy a cheap viola and practice it alongside the viola, just to learn more about it and enjoy the sound.
For example, I play in octaves relatively fast and effectively on the violin. Is the same technique as easy on the viola? _________________ "No one should be allowed to play the violin until he has mastered it."
Jim Fiebig |
Lemuel Site Admin
Posted: Sun May 01, 2011 12:00 pm Post subject: Re: Viola vs. Violin - the technique |
Basically the same principles apply for technique - bearing in mind that the viola is larger and heavier, your arm will be extended further out. Your fingers will have to stretch a little further apart for notes, octaves, double stops,...etc.
Since our minds are very habitual by nature, you will have to recondition your mind to match your bowing to the notes you want to play (Example: You would play some notes on the 1st string on the viola that you would normally play on the second string on the violin). |
Posted: Fri May 13, 2011 10:05 pm Post subject: |
Thank you! That's a great thing about playing a string instrument. You get an insight into a number of other instruments. _________________ "No one should be allowed to play the violin until he has mastered it."
Jim Fiebig |
gavin_rossdale Junior Member
Posted: Sat Apr 28, 2012 9:01 am Post subject: |
One other small adjustment I make is that I hold the violin a little more in front and the viola a little more to the side which I think is just a natural tendency due to the size of the instruments. |
matveimediaarts Junior Member
Posted: Mon Aug 27, 2012 1:11 pm Post subject: |
A 14" viola is the same size as a violin, only with different tuning. You may want to start with one of those. _________________ enjoy my art/music at www.matveimediaarts.blogspot.com |
