How do I better understand the scales?
Goto page Previous  1, 2, 3, 4
Oleg Vostyakov
PostPosted: Wed Nov 03, 2021 4:44 am    Post subject: Reply with quote
Lemuel wrote:
Oleg Vostyakov wrote:
I think you can find some practice decisions here- https://musescore.com/hub/museclass it is a good tool for learning and practice.
Thank you for posting this.
You are welcome Lemuel!
My scores works: https://musescore.com/sheetmusic
The program of training me as a musician: https://musescore.com/courses/violin
Mike Shuman
PostPosted: Thu Nov 18, 2021 1:57 am    Post subject: Reply with quote
Yes! Tht is good choice. I'm using it too!
I'm student in https://musescore.com/courses/master-the-violin-from-zero-to-advanced-level--LWNVW?lesson=a6xMd
PostPosted: Tue Apr 09, 2024 12:00 pm    Post subject: Scales Reply with quote
On a piano the black notes are either Sharps or Flats White notes are all Naturals .
For absolute beginners use a keyboard first. Play a C major scale using only 8 white notes. Listen to that as if it is a tune. Now start a major scale on an open violin string. The notes will be different to the piano but the sound pattern is what you need .
If you can "copy" the sound of a Major scale you are learning to hear what you are playing. Get used to adjusting your fingers to make the notes . The sound is more important than worrying about measurements between fingers . As you play further up the fingerboard the gaps will get narrower .
Now try to "copy" a Major scale pattern starting somewhere up the fretboard beginning with your first finger . First half on one string and second half on the next higher string . If you remember the spacing between fingers (roughly) you can play a scale anywhere you like . That would be harder on a piano .
Later you can learn about Positions on the fingerboard to give you a simple guidance system .
Every Major scale has the same Pattern of spaces between fingers .Remember the pattern and keep listening to make the notes in tune . Soon you will not need to look at your fingers ever again. Close your eyes and feel what your fingers are doing .
Feel .Listen and don`t worry .
Open G starts the key in one sharp.
Open D starts the key in 2 sharps .
Open A starts the key in 3 sharps
Open E starts the key in 4 sharps .
Page 4 of 4
